Author Subject: Heater blowing now and then
peugeot96
My heater motor has stop working, its work sometimes, but when l speed it up its stops. Any ideas ?
Posted 10th Sep 2014 at 21:42
Cjwatson27
It's could be the bearing on the shaft or a loose connection is it noisy at all ?
Posted 10th Sep 2014 at 22:11
anth
They are very easy to replace if needs be. Just under the dash on the passenger side. 10 minute job.
Posted 11th Sep 2014 at 07:19
try taking it off and coating it in WD40 etc and get it lubed up again
i'd use gloves the plastic blades on the sides of the fan are very sharp! Wink
Posted 11th Sep 2014 at 08:19
steve h gti-6
I had a similar problem and turned out to be a dodgy relay above the fuses under the drivers side dash . . . well it was in my Phase 3 6. Give it a tap or just swap it for another one to check
"Gotta Love The 6"
According to my wife i think the 6 is the fastest car in the world, perhaps she is right LoL !
Posted 17th Sep 2014 at 21:24
darkgti6
When I bad this problem it was a bad earth. To much hassle to trace the cable back to source so I ended up running a new earth. Problem solved. When it stops, just bridge the earth to the metal bar thats part of the dash to earth it and see if it starts again.
Team Peugeot Sport 308 Gti�
Posted 17th Sep 2014 at 22:33
pauldoubleyou
Concidentally, i pulled my centre console out and as soon as i pulled the plugs out of the demist and hazards the heater stopped working. This could be the culprit.
Paul
Hiding with Pride
Posted 22nd Sep 2014 at 11:48
