Author Subject: catcams 4903106
peugeot96
Have anyone tried this cams for the RS engine?
Posted 3rd Sep 2014 at 16:10
blandy
I believe these are what pug one off fit in there "195" bhp engine upgrade package. So they've fitted a fair few. Also these are one of the few cams people are still happy to fit in a standard engine without piston cut out modifications as there fairly mild
Posted 3rd Sep 2014 at 16:48
blandy
Posted 3rd Sep 2014 at 16:50
peugeot96
l see Pug1off claim they produce 195hk with ex.manifold and ported throttle body. But can these mild cams produce that much power?
Posted 3rd Sep 2014 at 18:45
blandy
Depends on rolling road and who you speak to I guess, they claim it will and people who like them will agree and others who don't will disagree.
Don't forget though there is a "remap" in that package also which is a map that they have so is designed to work with the cams but is not as far as a personalised map. I've not had any of this done by the way but a friend of mine has the package and is very happy with it.
Posted 3rd Sep 2014 at 19:03
peugeot96
How does your mates car pull vs a std gti6?
Posted 3rd Sep 2014 at 19:24
Joka-cro
Do you need variable cam pulleys for that cams ?
Posted 29th Sep 2014 at 21:56
p-silva21
I think you meant "adjustable" cam pulleys right? This engines don´t have variable valve timing.. Indeed the RS engine have adjustable cam pulleys as standard and I think you don´t need any other modifications to suit these cams as blandy said
Posted 29th Sep 2014 at 22:40
Joka-cro
yep,some models have some dont,my dosent have....
Posted 30th Sep 2014 at 20:13
yes they do, they will be the later single bolt type.
you cannot use aftermarket camshaft pulleys with the standard MM ecu as they don't have the camshaft position sensor trigger.
Posted 30th Sep 2014 at 20:16
