Author Subject: Wanted: Stud conversion kit
osm2121
Im looking for a stud conversion kit, M12x1.25, im fitting 15mm spacers with OEM wheels, so I guess with 80mm studs i´ll be fine.
If they are black, even better, and also flat washer nuts, also if they´re black would be great.
If not, where can I find some of these? Found little stuff on ebay
Posted 30th Aug 2014 at 13:39
devere
I cant remember where I bought mine from now.. But il try and remember, although im sure someone else will come up with something.
1 thing I would say from my experience though, is don't go for the Grayston ones. They don't have a shoulder between the thread for the wheel nut, and the thread that goes into the hub. I found this annoying as theres no way of getting them in to the same point easily. I know you should probably Loctite though.
There are other ones out there that im trying to remember, that have a shoulder you screw it in and up to.
Posted 30th Aug 2014 at 13:50
osm2121
This is what I´ve found so far (just ebay)
all this same kind, and as you say, apparently doesnt have shoulder, the unthreaded part is slimer than the thread so you can´t torque it to the hub? You can just pass it all the way to the other side through the hub, doesnt sound good to me
Posted 30th Aug 2014 at 13:57
devere
Yeh that's what I was meaning. Those are the ones im not so keen on. I bought ones with the shoulder to stop them going through, but as said, trying to remember where they were from!
Posted 30th Aug 2014 at 13:58
devere
Posted 30th Aug 2014 at 14:00
osm2121
Thats exactly what I was looking for! Thanks mate Thumbs up
Posted 30th Aug 2014 at 14:09
