Author Subject: Negative camber
peugeot96
Is it possible to gain any neg. camber by slotting the holes where the strut is fastened?
Posted 29th Aug 2014 at 22:17
I don't think it is buddy. Don't think the spring would seat right at the top, and im not sure on clearance of the topmount to the inner wing unless you were to possibly grind some away.
It's not something i'd attempt to do with standard topmounts, i can recommend the adjustable topmounts that Bridgecraft do, they are a work of art. Yes
Posted 29th Aug 2014 at 22:42
allanallen
You'll gain very little slotting the holes like Steve says above. You either want coilovers and spherical bearing top mounts or your hubs modifying for more camber.
Facebook
Posted 30th Aug 2014 at 07:15
peugeot96
Is it possible with coilovers fitted?
Posted 30th Aug 2014 at 11:57
allanallen
If You've still got the massive standard top mount no
Facebook
Posted 30th Aug 2014 at 13:22
devere
Just buy some adjustable top mounts and be done with it.
No point bodging it or cheaping out when they aren't all that expensive anyway...
Posted 30th Aug 2014 at 13:35
