Author Subject: Phase 3 EBD
I'm asking on behalf of a mate, he has a ph3 with ebd and unplugged the wiring loom to the pump after fitting some 6 pots.
He took it out for a spin and I think it locked up the NSF wheel and caused the caliper to stay on.
He managed to limp home and reconnect the wiring loom but now I believe both front brakes are sticking on a bit.
Any suggestions for an easy fix for this? I've not been to see the car yet but I'm assuming a simple fluid bleed won't fully cure it?
Thanks in advance.
Posted 12th Aug 2014 at 15:37
cant imagine the abs pump causing this.
Posted 12th Aug 2014 at 16:08
Yeah it does strike me as odd.
I imagined that the ebd would just function as normal again once plugged back in. Hmm
Posted 12th Aug 2014 at 16:13
Niall
Yeah this isn't the pump. Sounds like sticking pistons.
If you unplug the pump, it will just allow fluid to flow through the open plungers.
Posted 12th Aug 2014 at 16:18
That's what I thought, I've got him to open the bleed nipples to release any possible pressure left in there and they are still clamping the disc.
May have to put the standard calipers back on at this rate, we're leaving for the Nurburgring Thursday morning and I'm going to struggle to get over to his house before tomorrow night Sad
Posted 12th Aug 2014 at 16:44
if there's no pressure its probably paint on the pad backing binding in the caliper or on the pins.
Posted 12th Aug 2014 at 17:00
p.s, I'd recommend him keeping the EBD plugged in unless he adds a load compensator or re-plumbs for a bias valve.
the ring is the last place I'd be running dodgy brakes!
Posted 12th Aug 2014 at 17:05
Yeah, i'm heading over tomorrow evening to try and get the pads out, fettle them and re-fit them. All being well we'll be sorted after that, and the EBD will be left plugged in until we return and i sort him out with new lines and a bias valve.
Thanks for your input guys. Thumbs up
Posted 12th Aug 2014 at 20:17
Niall
Tbh the EBD is very good on 306s. Not very intrusive at all but the ABS on ph1 and 2 was far from great and just comes on for fun. Id keep it all there for now!
Posted 12th Aug 2014 at 20:20
daver6
Just back from ring with knackered load comp
Wishbone Polybushes available
Posted 14th Aug 2014 at 14:47
