RJ
| Author | Subject: pressure plate |
speedo306
Regular Location: Trinidad & Tobago Registered: 05 Apr 2008 Posts: 478 Status: Offline |
Hi guys just put in a new clucth plate and new clucth cable , i used back the old pressure plate but now i am not getting any gear in when i start the car but when car is off the gears goes in could it be the pressure plate ________________________________________ RJ |
allanallen
Seasoned Pro Location: Buxton Registered: 01 May 2007 Posts: 1,399 Status: Offline |
Have you put the plate in the right way around? ________________________________________ www.bridgecraftmotorsport.co.uk |
speedo306
yes and i also jack up the car put it in 1st gear and then started it then put my foot right down on the clucth Pedal wheel still moving do a pressure plate go bad________________________________________ RJ |
friction plate in wrong way round or broken clutch cable, or you did not get the clutch fork fingers behind the bearing.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
speedo306
yes did get clutch fork fingers behind the bearing and i put in a new clutch cable________________________________________ RJ |
speedo306
anyone ________________________________________ RJ |
Niall
Seasoned Pro Location: Epsom Registered: 06 Jun 2012 Posts: 1,941 Status: Offline |
New cable yeah? Try stamping on the clutch a few times. May just need to adjust a bit |
friction plate on wrong probably________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
speedo306
just put it down again and the friction plate right place ________________________________________ RJ |
