Author Subject: Brake Load Compensator Spring
RetroPug
The spring & rod on my brake load compensator valve on the rear axle has snapped in half.
This thread seems to suggest it may be possible to replace the spring in situ? Does anyone know if this is the case as I have another valve and spring on another car and it would surely be easier to swap springs than the whole unit?
http://www.306gti6.com/forum/showthread.php?id=87791&page=2
Posted 16th Jul 2014 at 12:00
easily done yes, the bottom end on the damper bolt just unclips, the top end has the plastic nut.
Posted 16th Jul 2014 at 12:12
RetroPug
Just the answer I was looking for.
Should easily get that sorted before the MOT then.
Thank you!
Posted 16th Jul 2014 at 14:08
