| Author | Subject: overfuelling |
mjt4130
Regular Location: hessle Registered: 29 Sep 2009 Posts: 200 Status: Offline |
My 6 is overfuelling and failed it's MOT. Have replaced the Lambda sensor and still just as bad. Is it worth trying an ECU reset before I do anymore sensor testing? Its got a daft sports cat if that makes any difference? |
mjt4130
Fast idle test: engine speed 2500-3000 co- 6.7% hc 292 lambda 0.847 |
Failed its mot on what ? Emissions ? If so then yes the cat will be the problem |
mjt4130
Yes, failed on emissions. |
Sports cat will be the problem then |
not likely, the CO is massively high, the cat wont bring it down that far, check the green ecu temp sender.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
welshpug! wrote: not likely, the CO is massively high, the cat wont bring it down that far, check the green ecu temp sender. Could be a combination of the more than one thing but I bet if you got a decent original cat emissions would come right down |
mjt4130
The green sensor is next on my list as the cat is welded to the rest of the system- Its a Cobra sport made in situ type thing. |
mjt4130
New ECT sensor and still over fuelling so trying a cat next. |
