Author Subject: Ignition and Fuelling
RallyeP6
Hi all, can anyone tell me what the ignition timing in Degrees is for a standard Gti6, standard cams, injectors and fuel pressure (3 Bar ?). And fuel pulse in milliseconds is, at idle.
I need some values to put into my DTA E48 map, just to begin with.
Thanks.
Posted 10th Jul 2014 at 15:56
RallyeP6
Any one have an idea of a starting point, something i can work with?.
Posted 18th Jul 2014 at 22:53
Have you tried the dta website for a base map download ?
Posted 18th Jul 2014 at 23:20
I'm not 100% sure but I think fuel pressure is 3.5 bar std ?
Posted 18th Jul 2014 at 23:22
RallyeP6
I asked Allan at DTA, but all he could give me was the crank sensor position, nothing on maps.
Posted 19th Jul 2014 at 00:10
No, it's 3 bar as standard. Yes
Posted 19th Jul 2014 at 01:12
Doesnt dtawin have any maps on it? I know dtaswin does.
try the 205 forum.
Posted 19th Jul 2014 at 08:10
RallyeP6
Thanks guys, just posted on 205Gtidrivers. I have read that Chipwizards is the place to go to for mapping but they are so far away from me.
Posted 19th Jul 2014 at 11:14
That's only if you have the original MM ecu, if its anything else I'd make the pilgrimage to Cornwall, well worth it tbh!
Posted 19th Jul 2014 at 19:08
Niall
Being in West Byfleet, i would go to Track and Road if i was you. They have mapped my car twice now and done an absolutely fantastic job!
Posted 19th Jul 2014 at 20:23
RallyeP6
Track and road looks interesting, but who is in Cornwall?.
Posted 19th Jul 2014 at 23:04
RallyeP6
Can someone tell me which of the two fuel lines that come up near the cam cover, is the fuel supply (high pressure). Is it the white or green hose joiner?.
Posted 25th Jul 2014 at 21:23
Niall
White Smile
Posted 25th Jul 2014 at 21:37
RallyeP6
Thanks Niall, i can plumb in the regulator tomorrow.
Posted 25th Jul 2014 at 23:14
So your going to put the reg on which line ?
Posted 26th Jul 2014 at 00:41
isn't the return a smaller diameter pipe?
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 26th Jul 2014 at 10:13
RallyeP6
From the fuel tank (white) - injector rail - pressure regulator - back to fuel tank (green).
Will mount the pressure regulator onto the bracket where the power steering pump was.
Both pipes on mine are the same diameter.
Posted 26th Jul 2014 at 12:59
