As per the KONI equipped Sport Suspension Kit for the ph3 306 gti6 99 2.0l 16v which lowers the rear by 35-40mm. Do I have to adjust the beam or will the shocks adjust to the desired 40mm.
RJ
| Author | Subject: Koni Equipped Suspension |
speedo306
Regular Location: Trinidad & Tobago Registered: 05 Apr 2008 Posts: 478 Status: Offline |
Hi As per the KONI equipped Sport Suspension Kit for the ph3 306 gti6 99 2.0l 16v which lowers the rear by 35-40mm. Do I have to adjust the beam or will the shocks adjust to the desired 40mm. ________________________________________ RJ |
midlife
Seasoned Pro Location: Colne, Lancashire Registered: 13 Mar 2006 Posts: 7,544 Status: Offline |
You need to have the beam lowered, the quoted drop is front only![]() ![]() ________________________________________ Get used to seeing the yellow one !!!![]() ![]() ![]() ![]() ![]() Team 330™ ![]() Team "no front end or engine" Team "LIMITED EDITION" I live for the 306 sticker ![]() Team 0-60 in 6.44 & standing qtr in 14.808 @ 94.55mph all with std engine ![]() 203bhp Corolla T-Sport daily driver stealthier than Kwai Chang Caine |
speedo306
midlife wrote: You need to have the beam lowered, the quoted drop is front only ![]() ![]() How can I tell if a beam has been already lowered. ________________________________________ RJ |
midlife
Someone may know the std distance between the shock mounts when the wheels are off the ground, just measure & compare.This was my Rallye dropped 50mm at the back.. ![]() Have fun ![]() ________________________________________ Get used to seeing the yellow one !!!![]() ![]() ![]() ![]() ![]() Team 330™ ![]() Team "no front end or engine" Team "LIMITED EDITION" I live for the 306 sticker ![]() Team 0-60 in 6.44 & standing qtr in 14.808 @ 94.55mph all with std engine ![]() 203bhp Corolla T-Sport daily driver stealthier than Kwai Chang Caine |
Capt Pedantic Location: Bigend, Wales. Registered: 27 Mar 2007 Posts: 25,868 Status: Offline |
dampers off & weight of the trailing arm supported they are 330mm between damper bolts as standard.that's a LOT more than 50mm Wayne ![]() ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
speedo306
i have a use vts beam ________________________________________ RJ |
midlife
welshpug! wrote: dampers off & weight of the trailing arm supported they are 330mm between damper bolts as standard. that's a LOT more than 50mm Wayne ![]() Well, I was quite fat then ![]() ![]() ________________________________________ Get used to seeing the yellow one !!!![]() ![]() ![]() ![]() ![]() Team 330™ ![]() Team "no front end or engine" Team "LIMITED EDITION" I live for the 306 sticker ![]() Team 0-60 in 6.44 & standing qtr in 14.808 @ 94.55mph all with std engine ![]() 203bhp Corolla T-Sport daily driver stealthier than Kwai Chang Caine |
Probably 60mm and 50 profile tyres lol. I'm pretty sure a VTS beam if at standard height is 25mm lower than a 6 beam or something like that. ________________________________________ Black power baby! SUUUUUPERCHARGED Seat Leon FR TDI 190BHP 300lbft daily gti-6 killer :p 12x 306's owned so far Cambelts, clutches, service work carried out on All makes and models, Peugeot Citroen / mitsubishi specialist. Pug planet / Citroen Lexia diagnostics / code reads available. |
