Author Subject: ECU map screen shot please??
devere
Bit of a long shot here. But does anyone here have a copy of there ecu map on the computer? For an Omex preferably, but dta etc will do.
Could anyone that has, put up a screen shot of there coolant fuel trim table please. The table showing the extra fuel added by the water temp.
Just wanted to compare it to mine, as I need to trim some of the fuel out as it's over fuelling when cold.
I know it's all dependant on engine etc, but I just want something to compare to that's all.
Cheers.
Posted 27th Jun 2014 at 09:04
Its dependent on fuel pressure and injector sizing too, tbh you just need to get a wideband on it and have a play, see where its happy.
Posted 27th Jun 2014 at 09:45
devere
That's what I'm doing. Got the wide band in and ready for starting it up for the first time in ages. It runs fine when warm just rich when cold.
I was just wanting to see if there was a rough curve to the coolant fuel graph that is the common shape. So I know if I'm heading for something vaguely normal!
Posted 27th Jun 2014 at 10:07
Niall
Ive got a Omex map for a standard 6 engine i can send you but ill be honest, the map is utterly s**te and massively over fuelled and barely started. Welcome to a copy if you PM me your emails address.
Posted 27th Jun 2014 at 18:09
rich_w
It's not - water temp compensation tables are normally done on a percentage basis from the base fuel map.
Contact Details:
07732 822546
Posted 27th Jun 2014 at 19:16
rich_w
I can provide some info - will try and post it over the weekend.
Contact Details:
07732 822546
Posted 27th Jun 2014 at 19:17
devere
That would be grand if you could rich.
I know it's a percentage of extra fuel. As you say, must be a percentage of the map value added in.
As said previously, I know it will mean checking the wideband but it's just to get a rough idea of the curve shape that's common. I think currently my map at initial starting water temp is adding 50% or more fuel.
Posted 28th Jun 2014 at 07:33
devere
Also, if anyone has a chance, maybe a screen shot of the Start fuel coolant table as well please.
As said, its for a reference point more than anything. I haven't a clue what other maps/engines would require for these.
Posted 28th Jun 2014 at 14:42
