displaying posts 26 to 33 of 33
Pages (2): 1 [2]
Author Subject: Compression Ratio
blandy
Ok scrap that couldn’t find anything on wossner via Peugeot but managed to find them under Citreon
blandy has attached the following image:
Posted 9th Dec 2017 at 21:53
so a +2.80 cc dome.
Posted 10th Dec 2017 at 00:09
blandy
Yeah according to the specs ... would appear I’ll be ending up with 13.39-1 ratio using this calculator (need to cc head still but using 37cc just to get a number)
https://www.rbracing-rsr.com/compstaticcalc.html
Putting the dome cc in as a -2.8 figure.
Posted 10th Dec 2017 at 10:04
is this for a 2.1 or 2.2 build?
Posted 10th Dec 2017 at 10:23
blandy
2.1 although may go with the 86mm crank if it’ll suit the pistons and rods better - the dry build is to see if i can machine the pistons enough for a sensible comp ratio (hydraulic lifters and catcams 110)
Posted 10th Dec 2017 at 11:18
blandy
Well done some measuring and by calculations I think the 88mm crank and my piston/rods will be to much compression unless anyone can advise as I’m plugging measurements into a online calculator
Basically I have
87mm bore
88mm crank
Piston dome 2.8cc
Head 37cc (yet to accurately measure)
Deck height -1.1mm
I was advised by a well know builder to run a 2.2mm cometic headgasket which I also have and that along with a “light skim” of the pistons to bring comp ratio down to a sensible level. Now playing on a calculator before touching anything I get 13.27:1 does this sound correct. I’m yet to have the block/head skimmed yet until all the measurements make 100% sense. Also still have my standard 86mm crank as a worst case scenario
Posted 10th Dec 2017 at 15:38
Good luck Michael Thumbs up
Mei is your man for that ....
Posted 10th Dec 2017 at 19:12
blandy
Thanks - I could just take builders advice and throw it together and hope for the best but I like to check things and as I’ve never built a petrol engine before trying to be cautious
Posted 10th Dec 2017 at 19:53
Pages (2): 1 [2]
