Author Subject: What is the black box above the drivers side wheel inside the wi
Rallyman
Hi guys,
Probably on here somewhere but I have been unable to find it. I have a black box above the drivers side wheel inside the wing. It appears to have air hose going from it to the throttle body. What is it and can it be removed from the car?
Posted 15th Jun 2014 at 20:20
flight data recorder
And a pito tube
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 15th Jun 2014 at 20:28
Rallyman
Not sure that I need the flight data recorder! Wink And I have no idea what a pitot tube does on the car.....So does that mean it can be removed without causing a problem?
Posted 15th Jun 2014 at 20:31
LOL:
its the charcoal canister.
Posted 15th Jun 2014 at 20:38
Rich E Forum Admin
It's the charcoal canister. The fuel tank vents into it, with the vapour being fed into the inlet manifold through the brown valve on the outlet hose.
Why are you considering removing it?
Posted 15th Jun 2014 at 20:39
Rallyman
Only reason is that after every event I have to strip the wing in order to clean all the mud etc from around it. Wondered if it could be removed or perhaps relocated.
Posted 15th Jun 2014 at 20:45
Bin it
Posted 15th Jun 2014 at 21:12
Rallyman
Thanks, Do I just link out the existing pipework so it still terminates in the manifold?
Posted 15th Jun 2014 at 21:17
put the wheelarch liners back on, job done.
Posted 15th Jun 2014 at 21:36
Rallyman
That leads me to the next question. Apart from the OEM Liners has anyone found a good alternative? I keep punching holes in the OEM ones.
Posted 15th Jun 2014 at 21:45
