Author Subject: Polished manifold and tb
greenie
So I missed out on the manifold and tb that Russian guy was selling this week :-(
Found one on eBay that has apparently been ported and polished.
I asked the seller how accurately it was done but no answer.
This is a precise procedure right ?
It needs to be done pretty well or it could screw up air pressures and flow?
It's £100 for both manifold and tb - should I give it a go or avoid?
Posted 13th Jun 2014 at 20:16
Cjwatson27
Make sure it runs on standard management i almost made that mistake
Posted 13th Jun 2014 at 20:32
I have a manifold.
Posted 13th Jun 2014 at 20:44
greenie
Hey welsh pug
I am looking for a ported/ polished manifold.
I'd like to see what I can get out of a n/a engine. I intend to recon the head later, ported and some hotter cams etc
What do you have ?
Posted 13th Jun 2014 at 21:06
Its a copy of the longman inlet from the BTCC 306's, but still works on the standard management, the longman engines ran EFI Euro1 with the map port blanked and the resonator blanked too.
Posted 13th Jun 2014 at 21:15
greenie
Sounds ideal.
Safe to assume I would need the throttle body modded to get the best out of it!
Change the injectors?
Ptfe gasket?
How much are you wanting for it?
Thanks for the info.
Posted 15th Jun 2014 at 10:46
