Author Subject: Electric PAS
eddy_gti6
Who is running a 106/saxo epas setup and how does it feel and compare to the standard 306 pas setup? Looking to get mine done hopefully next week to make room on the chassis leg for my header tank. I have had someone say it makes the steering heavier and doesnt have a good feel but just wonting to know what yous this with it on a 306. I have had plenty 106 and saxos before and never had any issues with them but then the 306 is a heavier car.
Posted 5th Jun 2014 at 19:39
Jammapic has elec power steering and said it was perfect
Posted 5th Jun 2014 at 19:48
eddy_gti6
I dont see why it would be any worse than standard to be honest
Posted 5th Jun 2014 at 20:43
It's not
Posted 5th Jun 2014 at 20:45
eddy_gti6
Smile thanks al stick with fitting one then. Was offered the option of running a corsa B electric column but cant pull myself to spend £200 on it!
Posted 5th Jun 2014 at 20:46
Niall
I've got 106 pas fitted to mine. At fcs this weekend? Feel free to have a go with the car if you like.
Posted 5th Jun 2014 at 23:29
eddy_gti6
No not at FCS. Bit of a shame as I would have liked to come just funds stopping me. This inlet has cost a fortune this month
Posted 6th Jun 2014 at 13:43
ravemercer
Ive got the 106 elc Pas. Not had any problems with it and I've not noticed any major diffrence in feel.
Posted 6th Jun 2014 at 21:57
eddy_gti6
Cool. Just picked my pump up todsy. Where do you have yours mounted ravemercer any pics?
Posted 6th Jun 2014 at 22:07
allanallen
£200 to supply and fit a corsa column? That's a bargain!
Well depending on the quality of workmanship
Facebook
Posted 6th Jun 2014 at 23:07
devere
Plenty of room in the engine bay. Mine is on the bulkhead, where the back of the battery box would usually be. With the battery now inside the car, and I have my header tank in front of it on the inner wing.
Posted 6th Jun 2014 at 23:37
devere
Posted 6th Jun 2014 at 23:38
eddy_gti6
Yeah I have been looking to fit the PAS pump on the bulk head and move my catch tank onto the chassis leg
Posted 7th Jun 2014 at 08:12
ravemercer
Mines on the passenger chassis leg close to the rad, fix with rivanut things. I've kept the original tank and most of the pipe work fits pretty snug Ill take a couple of picks inc the wiring.
Posted 7th Jun 2014 at 20:20
eddy_gti6
Got mine fitted today. All on well apart from the standard gti6 feed with 17mm bolt to lock the pipe into the pump isnt long enough so all my pas fluid came out through the 17mm bolt so need modify that then all should be well.
fitted mine to the same place a 106 has it fitted
Posted 7th Jun 2014 at 20:55
ravemercer
This is mine. Do you have the grey relay and any idea what the white wire coming off its for ?
Posted 7th Jun 2014 at 21:51
eddy_gti6
Thick Black wire is live, yellow is earth and green is live switch. I dont have a white one?
Posted 7th Jun 2014 at 21:53
ravemercer
Took my kit off another 6 and wired the same to mine had this white cable that was spliced into a cable in the engine bay fuse box always wondered what it was for never looked into it tho.
you can just see it top right had of the picture.
Posted 7th Jun 2014 at 22:11
ravemercer
looks like our wiring is different then I've got a thick red live, thick green earth and a small green earth from relay along with a unknown white from relay.
Did you get yours running at all ?
Posted 7th Jun 2014 at 22:19
eddy_gti6
Yes mine runs but p**ses fluid out. Getting a new pipe made through the week to sort this out tho
Posted 7th Jun 2014 at 22:33
