Author Subject: cooling fans
chiefton
Right my rad fan doesn't work iv taken the cover off the fan relay housing and found this wire just wrapped around the other wire.....
with that wire joining the main loom that comes from the main engine loom plugs like so..
so that defo not right lol any idea what that is??
Also just bought some slimline fans would it be easier just to wire these in and remove the fan cowling completely?? What the easiest way to do that if it is the way forward.
they havnt worked since iv had the car so....
thanks
cherry rallye daily (the money pit)
Posted 3rd Jun 2014 at 15:39
chiefton
Nobody know??
Posted 5th Jun 2014 at 16:11
alcon
I had a similar thread recently....and no one responded, so don't worry. Sounds like we have similar problems with rallye fans! I also had some dodgy wiring like yours (inherited from previous owners) and needed to sort it out in order for fan to work. I ended up salvaging the loom from a breakers then stripped out all the botched wiring in my car. I managed to plug the new loom into the fan and into the rad but the third connection into the main loom seemed to be slightly different (like male to male pins). I'm a stage further forward but the fan still doesn't work yet!
Any info you have would be great
1999 GTi-6 (china blue)
1999 Rallye (black)
Posted 5th Jun 2014 at 20:30
I'd ditch that loom and cowling and replace with std none aircon stuff Thumbs up
Posted 5th Jun 2014 at 20:52
alcon
Chris, do you know if the Rallye setup is similar to lesser 306 models or is the fan wiring loom different/unique to the rallye? (sorry Mark, not trying to hijack your post here Thumbs up )
1999 Rallye (black)
Posted 5th Jun 2014 at 21:00
superchargedblack1997gti6
Mate I have a spare rad and fan shroud somewhere if you want to have a play round?
Posted 5th Jun 2014 at 21:02
alcon
Remember the GTi6 has the twin fan setup and the Rallye has the single fan, although I think the shroud in the same in both models.
1999 Rallye (black)
Posted 5th Jun 2014 at 21:07
rallye would be the same as a non turbo diesel and similar, the TD non AC setup still has has twin fans but controlled by a thermoswitch.
Posted 5th Jun 2014 at 21:11
alcon
The loom I stripped out the breakers yard seemed to be ok on two of the three connections but had multi pins on the third end, which clashed with pins on the plug i was trying to connect to. I was expecting pins and plugs at that connection. I'm not sure what model I got it from but it was definitely not a Rallye or a TD.
1999 Rallye (black)
Posted 5th Jun 2014 at 21:22
chiefton
that be awesome mate I can return your Inlet mani too you at same time!
I do have a couple slimline fans bit don't have a clue how to wire up.
Posted 5th Jun 2014 at 21:41
chiefton
right more investigating today...found that the rad switch on the rad itself had broken wires so replaced using new terminals on the ends....done. got live to the switch and if I earth my test light then press on middle (white ) wire double speed fan cut in but still now joy cutting in when hot....aaarrrggghhhh annoying these little thing can be ay!!! lol
may just wire my slimline fan to a switch where the headlamp level should be at side of steering wheel and be done with it!!!
Posted 9th Jun 2014 at 19:04
cully
is the fan single speed or duel speed on the rallye?
Posted 9th Jun 2014 at 21:27
dual speed single fan with resistor for low speed controlled by a thermoswitch.
Posted 9th Jun 2014 at 22:07
