Author Subject: Wrong Spark plugs
When I bought the 6 just over a year ago I was told New cam belt & Plugs plus Oil filter & oil was fitted ....
Well I've changed the oil & filter 6 months ago & today I changed the plugs as starting was getting difficult & FCS on Sat & Sunday changing them made sense !
The 6 starts amazing now Thumbs up
Well I fitted NGK BKR6EZ & took out
Some strange looking & unknown plugs ?
NGK BKUR7ET with 3 ground Electrodes ????
Posted 2nd Jun 2014 at 20:59
buzzbrightyear wrote:
I Wouldn't worry about it they all do same thing wether there's 1,2,3 or 4
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 2nd Jun 2014 at 21:04
RetroPug
I hope you mean that you fit BKR 6EK!
Posted 2nd Jun 2014 at 21:15
Nope EZ m8 !
Will try them ...
Posted 2nd Jun 2014 at 21:37
bas_306gti
The BKR6EK is almost the same spark plug as the BKR6EZ.
The EK has 2 elektrodes instead of 1.
The BKR5EZ/EK is the wrong spark plug, this plug is too warm and can cause pinking.
Posted 4th Jun 2014 at 12:06
studarude
Just FYI, the BKR6EK plug is listed on loads of stuff on ECP, if you search for 408110050 it'll get you to the right plug.
Posted 6th Jun 2014 at 11:44
I've not fitted BKR5 ????....which you correctly said is the wrong plug !!!!....or were you telling the other chap Thumbs up
As you rightly said 1 electrode instead of 2 & NGK said same Temp band 6 ...
Now out looking for Correct Ek plugs !!!!!....Crazy
Got BKR6EKs Whistle
Posted 6th Jun 2014 at 15:18
bas_306gti
The BKR5EK or EZ is listed in the NGK catalog as the right spark plug for the xu10j4rs engine however this spark plug has a heat range which is too high, as result engine damage may occur, the BKR6EK or EZ is the right spark plug.
The correct plug is the NGK BKR6EK.
I don't know if it makes any difference if the spark plug has one or two electrodes, so the BKR6EZ may also be correct.
Posted 6th Jun 2014 at 22:32
bas_306gti wrote:
The BKR5EK of EZ is listed in the NGK catalog as the right spark plug for the xu10j4rs engine however this spark plug has a heat range which is too high, as result engine damage may occur, the BKR6EK or EZ is the right spark plug.
After the posts ..I today rang NGK & was told both 6 heat range but EZ doesn't have v shape inside ???? & is for 2.0 stnd not Gti6 ...they said twin electrode is for reliability & has no more performance gains.!!!
That's what they said Big grin
So now changed mine to BKR6EK ...but a worry was he kept saying Iridium plugs are for track days & are better ???
Non of the race guys I know use them ?....but there again some strip down the engines after 3 meets LOL
Posted 6th Jun 2014 at 21:11
indeed no need for wasting your hard earned on Iridium plugs, I guess Di and Turbo engines might benefit from them, but I know Sandy brown uses and recommends just a standard NGK plug, 7 range if its higher compression than standard.
Posted 6th Jun 2014 at 21:37
bas_306gti
Iridium plugs have a only a longer life than a normal spark plug, but they cost more.
There is no increase in engine power.
Posted 6th Jun 2014 at 22:40
Original pug plugs all the way shame they no longer sell them
Posted 6th Jun 2014 at 22:44
RetroPug
Didn't they come with NGKs or Champions from the factory?
Posted 7th Jun 2014 at 00:34
