Author Subject: P bush 13mm bolt
Markie
I recently put some new wishbones with vibratechnic p bushes on, have just been under the car to check the bolts and one of the 13mm bolts that go into the p bush won't tighten up. The bolt will undo and tighten up to a point then it just keeps turning quite freely. New bolt? Really don't want to have to replace the p bush. No
Posted 2nd Jun 2014 at 15:45
craig903
take the bolt out and have a look at the thread. if the thread looks decent then unfortunatly you've most likely stripped the thread in the p bush.
208 GTI Owner
Posted 2nd Jun 2014 at 16:10
Markie
Will have a look when I get back; I really hope it's not the p bush, cant afford a new one!
Posted 2nd Jun 2014 at 16:36
rallyestyle
Can you not tap the thread and use a bigger bolt if need be? Unsure
Just Drive It
Posted 2nd Jun 2014 at 19:05
