Author Subject: Crank sensor dead?
Markie
Hi guys, need some help! Car's been sat for a month whilst i've been working on it, went to start it today and it won't fire up. It turns over and the fuel pump primes, from what i've read on here it sounds like it could be the crank sensor? or could it be the ecu? Also, where is the crank sensor located?
Thanks.
Posted 26th May 2014 at 14:03
crank sensor is bolted to top of the gearbox right where it meets the engine, black plug with a 10mm bolt holding it on. google images > "gti6 crank sensor"
have you physically checked for spark and fuel at the rail?
Posted 26th May 2014 at 14:27
Markie
Haven't checked that yet, i found this...
... behind the battery box. Could this be the culprit?
Posted 26th May 2014 at 15:19
That's the fuel relay from behind the battery box ? What work have you been doing the car ?
Posted 26th May 2014 at 15:23
Markie
I changed the passenger side wheel bearing, p/s cv boot, replaced front brake lines, calipers, flexi hoses. I had the battery box detached so i could unplug the abs sensor, must have hit the relay whilst the box was detached! Doh
Posted 26th May 2014 at 15:36
If the pump is priming then it's working but worth changing I guess ? It's got fuel in the car I assume ?
Posted 26th May 2014 at 16:15
Markie
Yeah it's got fuel in, the light's come on though. Will put more fuel in and change the relay and see if that helps.
Thanks
Posted 26th May 2014 at 16:27
Markie
I'm pretty sure the pump is priming, though i remember hearing a clicking sound before... might be imagination though. Wink
Posted 26th May 2014 at 16:29
Try the fuel cut-off switch. It's a big red button by the top suspension mount on the battery box side.
Make sure you haven't bumped it and it needs resetting. If it does, just press it to reset it. Yes
Posted 26th May 2014 at 16:46
mechanical_repairs
Looking at the crack in the double function relay I would say if the red button is ok that will be your culprit.
Carl
Posted 26th May 2014 at 20:42
Markie
I tried the cut off switch which didn't resolve the issue, if it is the relay would the engine management light not light up on the second ignition turn?
Posted 26th May 2014 at 21:25
mechanical_repairs
The relay does two functions, it supplies the fuel circuit and also the ignition circuit, I change a lot of these when they have been damaged like your have the contacts inside corrode, open it up and hold the contacts together, that will give you a definite answer.
Carl
Posted 26th May 2014 at 21:43
Markie
Thanks guys Thumbs up
Posted 26th May 2014 at 22:08
Markie
I might try and get a relay from the breakers as peugeot want 45 pounds which i dont have at the mo, does anyone know what other models are compatible?
Posted 27th May 2014 at 09:19
pull the casing off it and check it for water damage but that's a common issue as well
Posted 27th May 2014 at 09:30
Markie
All sorted now, fitted new relay. Thumbs up
Posted 27th May 2014 at 22:14
