Author Subject: Electric window switch
t3ora
Is there different types on different phases (pin locations etc)
Road/track car coming together slowly
Posted 25th May 2014 at 20:46
Puggitt
Well phase one has seperate toggles for each window, the phase 2and 3 are in the arm rest in the doors in a mould surround plus drivers side combine with mirror adjustment
Posted 25th May 2014 at 21:11
Niall
Only difference with the ph2 and 3 is if it had a auto drivers window or not. If it doesn't, you have to fit the door loom with the auto switch otherwise it will just blow fuses and vice versa
Posted 25th May 2014 at 21:30
t3ora
That might be my issues with my windows then
It's got a ph2 window switch (car was stripped when bought) and the windows don't work
Looks like a phone call to the dealer Tuesday to see wot switch should be there
Posted 25th May 2014 at 21:46
