What's the function of the spring attached to the clutch pedal, inside the car.
I just can't figure it out what it is needed for, I thinks it makes the pedal more heavy than it's supposed to be.
| Author | Subject: spring attached to clutch pedal |
bas_306gti
Regular Location: Eindhoven Registered: 06 Sep 2012 Posts: 108 Status: Offline |
Hi,What's the function of the spring attached to the clutch pedal, inside the car. I just can't figure it out what it is needed for, I thinks it makes the pedal more heavy than it's supposed to be. |
bas_306gti
It is nr. 4 on the picture: |
it doesnt keep the pedal up, it pushes it down to keep tension on the self adjusting cablethere was a peugeot tech bulletin to remove them. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
bas_306gti
Does this tech bulletin mention the reason it has to be removed ?As far I can see it only fitted to the XU10JR(S) models. |
scotzman
Seasoned Pro Location: Dundee Registered: 24 Jun 2011 Posts: 1,408 Status: Offline |
bas_306gti wrote: Hi, What's the function of the spring attached to the clutch pedal, inside the car. I just can't figure it out what it is needed for, I thinks it makes the pedal more heavy than it's supposed to be. Man up!!! its supposed to be heavy, you can tell a 306 driver by the girth of his left thigh ________________________________________ '90 1.6 205 GTi, '98 306 GTi-6 |
