Author Subject: Gear linkage problem.
oldbrownshoe
Gear Shifting in my ZX Reflex became almost impossible,
i don't know the parts name, it should be some kind of ball bearing,
i've been told that the original part is made from some sort of plastic called Ocolon,
i prefer metal made aftermarket parts,
no one sells this in Israel.
what is the exact part nam ?
where can i find it online ?
French military victories?
Did you mean French military defeats?
Posted 21st May 2014 at 18:46
oldbrownshoe
GSF let me down.
Posted 20th May 2014 at 17:32
oldbrownshoe
Problem solved, thanks for all the enthusiastic responses.
Posted 21st May 2014 at 16:23
No worries, which part was causing issue??
306 parts fit fine, though zx gearstick is shorter, essentially a quickshift!
Posted 21st May 2014 at 16:29
oldbrownshoe
My mechanic said it's the 2 parts circled in black that need to be replace
part 5 & part 3,
anyon know "carscenter" seller in EBAY.UK ?
Posted 21st May 2014 at 18:47
ah, TU engine with a single rod MA gearbox?
Posted 21st May 2014 at 18:44
oldbrownshoe
Yep.
oldbrownshoe
Got the parts, but i'm not sure how to remove the old part, if it's just brute force or some sort of tool.
that's how it should be after removing
and that is now
Posted 5th Jun 2014 at 15:33
oldbrownshoe
Managed to pull that plastic out without destruction,
now i think there a usage of grease between the ball and the plastic,
is any kind of grease will be sufficient or it's special one ?
Posted 5th Jun 2014 at 16:59
oldbrownshoe
after few days with the new parts, the gearshift is sticky again,
there is no tuning rod length in it, i can remove all of it to check but i'm not sure if it worth the effort.
Posted 24th Jun 2014 at 15:10
oldbrownshoe
Problem solved by my mechanic 2 minutes work no charge, i'm ashamed i couldn't solve this myself,
it was too simple but i couldn't connected the dots.
Posted 16th Oct 2014 at 08:28
Did you sort this?
What was up then?
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 16th Oct 2014 at 10:32
oldbrownshoe
The clutch separating point was too low, he just tune the cable to a higher point.
ii's not perfect cause' i prefer to release the clutch at the beginning of travel.
Posted 16th Oct 2014 at 11:47
