Author Subject: Diablo red turbo '6
craig903
So this is my turbo project started back in january 2014!
Spec so far
ENGINE
0.5mm rebore and rehoned, crank polished
Lynx garage Head gasket and bolts
ACL/KING Heavy duty/uprated main and big end bearings
Woessner low compression 8:1 pistons
Pec steel conrods
Peugeot genuine oil pump chain and latest revision key'd chain sprocket.
Brand new genuine water pump
Thermotec inlet manifold and rocker cover gaskets
All other gaskets/seals are all genuine peugeot
Gt3071R Turbo
Teflon braided oil feed, return and water lines.
Dp engineerings manifold and downpipe
KMS 4 bar map sensor
electronic boost solonoide
Rally design catch tank
Mocal 19 row oil cooler with thermostatic oil sandwitch plate.
Larger radiator
Large intercooler 600mm x 300mm
Baker bm engine mounts
Baker bm thermostat adaptor
205 top hose outlet
Bosch 044 fuel pump
Additional billet fine fuel filter
Underboot swirlpot
Stainless braided fuel lines
ANSU 800cc Injectors - Too big so far
RichW billet lighened flywheel
RichW billet crank pulley
Helix 4 paddle ceramic friction plate and uprated pressure plate.
Kazz Driveline 3J plate diff
BRAKES
Highspec 4 pot calipers and 330mm discs
SUSPENTION
Bilstein B12 suspention kit with eibech pro springs
Front struts rebuilt with everything new
Lemforder front wishbones
Lemforder lower balljoints, antiroll bar bushes and anti roll bar links
RichW roller wishbone bushes
Lemforder Topmounts
STEERING
Xsara 2.4 steering rack with new gaitors
lemforder trackrod ends
MOMO Steering wheel
OTHER
Custom strut bar
orginal front panel but it has been powder coated.
Safety devices roll cage with additional harness bar welded in
Alloy Boot battery box
In boot washer bottle
Corbeau Sprint grp/kevlar bucket seat
Rally design 6mm seat mounts with welded in bars
208 GTI Owner
Posted 1st Jun 2016 at 20:50
RetroPug
Watching with interest!
Posted 11th May 2014 at 14:26
have fun tightening those manifold nuts LOL
Posted 11th May 2014 at 14:28
craig903
Ha ha I know! Not very clear indication but their is a safe gap for the nuts.
208 GTI Owner
Posted 11th May 2014 at 14:36
fatlapit
Good luck bud 480 will be crazy.
Posted 23rd Mar 2015 at 22:52
fatlapit
Just run it by me how your gonna achieve this under 10k??
Posted 24th Mar 2015 at 08:57
Eddleston
This looks like it's going to get interesting!
Posted 24th Mar 2015 at 12:26
lj_6
This is going to be interesting! But one thing I will say, 480bhp on an internal wastegate? I think you'll have to upgrade to external as it will struggle on internal. Good luck with it though !
Astra burg #365 Garrett Power
'99 bodied 6 track project
Posted 24th Mar 2015 at 12:51
fatlapit
Wat injectors u gonna use??
Posted 24th Mar 2015 at 19:45
Cjwatson27
Good to see this car back on the forum
Posted 24th Mar 2015 at 21:19
craig903
I realised i must have been on crack when i originally wrote this so I've edited the main thread, updated things really.
208 GTI Owner
Posted 25th Mar 2015 at 20:59
craig903
Looking like i will be going for around 680cc injectors, atspeedracing sell some pico ones.
208 GTI Owner
Posted 25th Mar 2015 at 21:20
I always wondered when I see these turbo build pictures, do they have a bracket from the engine/g box to support the turbo or does it just sit there on the manifold and downpipe?
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 25th Mar 2015 at 21:24
if the inlet will allow it you'd probably be better off with two sets of smaller injectors.
Posted 25th Mar 2015 at 21:26
craig903
I baught mine from atspeedracing and it never came with a fitting kit or the turbo support but if you buy from dpengineering the supply these. I never new this at the time i baught mine. At the moment its just sitting on the manifold but there will be a support.
208 GTI Owner
Posted 25th Mar 2015 at 21:59
craig903
What would the advantages be?
208 GTI Owner
Posted 25th Mar 2015 at 21:30
fatlapit
I run single asnu 650 Cc injectors
Posted 25th Mar 2015 at 21:51
Very interesting
Watching this with great interest ....Thumbs up
Posted 25th Mar 2015 at 22:49
99rallye
That engine bay looks awesome!
Posted 26th Mar 2015 at 07:20
straki007
Nice
Posted 26th Mar 2015 at 08:14
