Author Subject: Dodgy idle / cutting out
matt16v
Hi all,
Have had this problem a few times, tends to be after a few stop start journeys, engine warm. Upon returning to the car after leaving it for an hour or so, it starts well as normal and sits at about 900rpm but doesn't feel quite right, then over 20 seconds or so the idle dips and dips until it cuts out. Start again and it'll do the same, start a third time and it's steady as a rock and drives like it too. If I blip the throttle it'll stop it from stalling but still doesn't run 100%.
Goes through thousands of miles driving perfectly, then this dodgy idle, then back to perfect.
Any ideas? Dunno
1999 Astor Grey GTi-6 OEM+
Posted 5th May 2014 at 22:19
RetroPug
The first thing I'd look at is the ICV. You can test it with a multimeter, however cleaning it up might cure the issue.
There is a guide in the FAQ section if you are unsure of how to do this.
Posted 6th May 2014 at 11:07
matt16v
I did clean it last year, sorry should have mentioned that. I'll give it another go.
Posted 6th May 2014 at 15:48
pebbles167
Every 6 I've had does this at some time or another.
Nearly always the ICV or MAP.
2005 Peugeot 206 GTI 180
2008 BMW K1200R
Posted 6th May 2014 at 16:55
Another vote for dirty/worn ICV. Yes
Posted 6th May 2014 at 22:45
RetroPug
Could be dirty again or needing replacement....as previously said, it is possible to test them with a multimeter, there is a guide in the FAQ.
ICVs are such a common fault on these though that if money isn't tight a new replacement one would probably be good.
Posted 6th May 2014 at 23:04
