Author Subject: Any benefit from uprated cams on LB supercharged engine?
thomo6
As per title does any one have any feed back or opinion? Am sure that I have read on here that it would actually be detrimental to the power of a LB supercharged engine to change the cams, but can't find the thread now.
Thanks in advance.
Posted 4th May 2014 at 11:26
No gains, stick with standard, been discussed before, hotter cams actually reduce power.
Posted 4th May 2014 at 11:38
Well that's not strictly true you could get some cams made to a specific spec for forced induction but off the shelf cams are designed for n/a
Posted 4th May 2014 at 12:01
p-silva21
IIRC Cat Cams have a Trubo/SC spec cams, send them a message...
Posted 4th May 2014 at 12:09
To make more power from a LB SC conversion, you would need milder cams as stated, not the uprated ones which have higher lift and make the engine more peakier. No
To be fair though, if you need more power than a LB SC with std cams gives you, then you're probably best off going for HB. Yes
Posted 4th May 2014 at 14:55
thomo6
Thanks guys for the clarification and replies.
Posted 4th May 2014 at 15:39
