Author Subject: Driveshaft Bearing
bruce2007
Just wondered if anyone could give me an idea how to get the bearing off in the middle, I might be being thick but I'm at a loss.
bruce2007 has attached the following image:
Posted 23rd Apr 2014 at 10:56
a long puller and some heat.
you need to shift the retaining collar first.
Posted 23rd Apr 2014 at 11:03
alcon
is the puller to get the collar off I take it?....does the bearing then just slide off or does that need pulling as well?
1999 GTi-6 (china blue)
1999 Rallye (black)
Posted 29th Mar 2021 at 23:38
both will need pulling, might be able to do it with a press instead of a very long puller, but you'll need the jaws of a bearing puller to go behind it
get it all set up and under pressure and warm up the collar with a mapp torch.
use a length of tube to press the bearing into place, you can then heat the collar and drop it on.
bearing is a common side, 6006 from memory, 30x55-13
Posted 30th Mar 2021 at 19:32
alcon
thanks, I'll try that. You're correct about the bearing size....30x55-13 (or part no. 3247 03). SNR also do one which is part no. 6006.
1999 Rallye (black)
Posted 30th Mar 2021 at 20:58
