Author Subject: tappets
Stillj20
How would I go bout getting a set of tappets for my phase 1 gti6.
Posted 22nd Apr 2014 at 11:43
get your wallet out, hand over cash, walk away with empty wallet and box of tappets.
Posted 22nd Apr 2014 at 12:22
LOL
Posted 22nd Apr 2014 at 12:27
You mean lifters ? It is possible to refurb a set ? Think I saw something in you tube ?
Posted 22nd Apr 2014 at 12:35
in most cases they can be revived by stripping down cleaning and re-dressing the top surface.
Posted 22nd Apr 2014 at 14:08
Stillj20
Got a price from main dealer of 27.54 + vat each, scoldy. Tryin to revive the old ones maybe the solution.
Posted 22nd Apr 2014 at 19:44
aaron6
Sure you want lifters and not valves?
Got a tap?
Posted 22nd Apr 2014 at 19:50
Stillj20
Goin to get her timed up properly first and do a compression test and see what the story is, worst case scenario is ill need a set of lifters aswell
Posted 22nd Apr 2014 at 20:10
Bet it's a bent valve or few....
Posted 22nd Apr 2014 at 23:30
This did make me Laugh my ass off
Posted 22nd Apr 2014 at 23:36
100% agree unfortunately.
aaron6
Thats what I was getting at. I have a dodgy tappet and quietens down after a few minutes.
Posted 23rd Apr 2014 at 07:02
Compression test won't show up a bent valve, when they tap they still seal correctly just tap as they hit the valve seat and eventually the valve falls in half and ruins the engine. Some last months others years. If it sounds the same hot and cold you've got a bent valve.
If it comes and goes loud and quiet depending on oil temperature among other things then it's probably a tappet.
I've heard about pattern ones being utter s**te so if it's tappets buy genuine once and save yourself the hassle.
Or just turn up the stereo Whistle
Posted 23rd Apr 2014 at 08:00
Stillj20
The sound is much the same whether its hot or cold, mite be cheaper to source a good cylinder head, if theres one to be had
Posted 23rd Apr 2014 at 17:27
Yup get a known good cylinder head and don't f**k it up when putting it on
Posted 23rd Apr 2014 at 18:17
Don't waste your money on tappets - they will NOT solve the issue...
Posted 23rd Apr 2014 at 23:32
Stillj20
Sound advice, just goin to wait and see if I can get a decent cylinder head.
Posted 24th Apr 2014 at 14:30
RallyeP6
Just done a 1400 mile round trip to Scotland with one intermittently noisy lifter, got so loud on occasions it was embarassing. It mostly seemed to happen above 3000 RPM for long periods, then next day quiet again.
Posted 24th Apr 2014 at 23:41
Stillj20
Would bent valves cause the car to cut out when the engine gets up to temperature, engine check light is on and after tryin everything to get her started.
Posted 25th Apr 2014 at 13:13
If the valve head drops off maybe.
Posted 25th Apr 2014 at 13:18
