can someone help as im confused I think it might be one of the coilpack is on its way out but maybe wrong
thank you
good to go!!
| Author | Subject: warning light flashing |
calumsaddler
Junior User Location: wakefield Registered: 02 Sep 2013 Posts: 66 Status: Offline |
My warning light is flashing like the clappers and the headlights flicker and when the car is on tick over the engine feels like it is going to cut out can someone help as im confused I think it might be one of the coilpack is on its way out but maybe wrong thank you ________________________________________ good to go!! |
pebbles167
Seasoned Pro Location: Melksham. Wiltshire. Registered: 08 Dec 2009 Posts: 2,516 Status: Offline |
If a coil pack has failed it will be running on 3 often, Ie; Horrid. Any idea if it is or not?Start engine with each coil pack removed in turn. When the engine doesn't run any different, you've found the culprit ![]() Otherwise it could be, ICV, MAP, probably some other stuff i cant remember, but others will. ________________________________________ 2005 Peugeot 206 GTI 1802008 BMW K1200R |
calumsaddler
Sweet ill try that after work and not sure I didnt think about it at the time I just took it straight home cause it was like 3 in morning . hadn't had the chance to look at it yet hope it is tho :/ ________________________________________ good to go!! |
RetroPug
A very simple 5-minute thing to try before spending any money might be battery terminals having a poor connection, loose connectors or crap all over them can cause all sorts of issues.Clean them up and refit them tightly. ________________________________________ 61k miles Ph.1 Diablo '6 Project Thread |
which warning light?________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
pebbles167
If its the STOP light, could be the bitron (spelling? ) located in the wheel arch. Vague memories of that being mentioned before. ________________________________________ 2005 Peugeot 206 GTI 1802008 BMW K1200R |
Sounds like coil pack? Simple way to check is unplug each injector in turn if one makes no difference to poor idle then that coil is fvcked |
calumsaddler
Ya its the stop light Ive just been out and the revs are bouncing like mad have to rev it when Im stood still to keep it from dying and when I stopped I lifted the bonnet and both fans where on full blast, the engine was red hot but the temp gauge was reading normal running temp ________________________________________ good to go!! |
scotzman
Seasoned Pro Location: Dundee Registered: 24 Jun 2011 Posts: 1,408 Status: Offline |
Any coolant left in it?________________________________________ '90 1.6 205 GTi, '98 306 GTi-6 |
calumsaddler
Ya im sure. I check it every long drive, I drive to from leeds to winchester like 2 twice a month unless it leaked out somewhere its one thing after another lol ________________________________________ good to go!! |
RetroPug
It could just be the ICV. I had a gunked up ICV that caused the stop light, poor idling and stalling.The headlights may just be the car being close to stalling. ________________________________________ 61k miles Ph.1 Diablo '6 Project Thread |
calumsaddler
Ill go check now, is it the sensor on top of the butterfly housing (white sensor)? ________________________________________ good to go!! |
RetroPug
It is next to it in a plastic casing with its own air feed that branches off of the main induction pipe.http://www.306gti6.com/forum/showthread.php?id=20477 ________________________________________ 61k miles Ph.1 Diablo '6 Project Thread |
calumsaddler
Ive cleaned it seems better but still think it need replacing to stop light is not flashing no more thank god lol cheers guys________________________________________ good to go!! |
