Author Subject: triangle relay box on fans
eddy_gti6
I k ow the 2 green relays are 1 for each fan but what is the black one for? I am on fitting a slimline fan and wondering if I need to keep the black relay or not? I can unplug it and my fan still works but I dont want to get rid of it incase its for the temperature sensor or something?
Posted 20th Apr 2014 at 16:31
all three are for the fans.
Posted 20th Apr 2014 at 16:44
Niall
The two green ones just switch a high current line to each fan. The black one switches them two green ones as and when they need to come on.
Posted 20th Apr 2014 at 16:57
eddy_gti6
So can I run a single slime line fan on 1 green relay and get rid of the black one and one green one? Already removed one green relay
Posted 20th Apr 2014 at 17:40
Niall
What exactly are you doing? Are you running the new single slimline with the Omex? If so, do away with these fans and relays all together, get a standard 40a relay and just wire it up with that. Much easier than messing about trying to set all of that up.
I also assume you don't have air con your planning to use lol
Posted 20th Apr 2014 at 17:55
