Author Subject: 307 xsi 302mm discs
eddy_gti6
Anyone know if the above discs will fit with 406 brembos? Are they the same offset ect... as xantia v6 discs?
Posted 16th Apr 2014 at 00:50
Too big.
Posted 16th Apr 2014 at 05:52
eddy_gti6
Not think you could squeeze the extra 14mm under the brembos?
Posted 16th Apr 2014 at 23:48
If you ran 406 hubs yeah.
Posted 17th Apr 2014 at 07:01
eddy_gti6
Straight fit on a gti6 the 406 hubs?
Posted 17th Apr 2014 at 09:08
jorg
are you trying to still use them under 15" alloys?
306 2.1 S16 Tarmac Rally Car
Posted 17th Apr 2014 at 09:23
eddy_gti6
Yeah. Take it 288mms going to be my limit? Been lookin to see where I seen someone running 300mm discs under 15s but cant find it. Sure it was with 406 brembos too?
Posted 17th Apr 2014 at 09:36
jorg
288mm is the limit under 15s yes Yes
if you went with a 406 hub the mount tab is further out than the 306 ones so i doubt you would get the alloy over them. i use 300mm rotors but with 6 pots, i know a few people use 310s but again that is with different calipers.
with the right combination of alloy and caliper i can get 325mm rotors under a 15" alloy Ninja
Posted 17th Apr 2014 at 09:50
eddy_gti6
Ah well looks like I will be sticking with the 288mm discs for now. Thought about running 16s but I just like my little 15s LOL may look into something new once engine is finished.
Thanks for the info lads Thumbs up
Posted 17th Apr 2014 at 09:55
