Would also like uprated springs. Ideally 450lb to fit kw variant 1 coilover. Will consider different rates but no lower than 400lb
| Author | Subject: roller bearing p bushes. 400lb springs. |
Phil white
Regular Location: Harrogate Registered: 29 Jun 2013 Posts: 223 Status: Offline |
As per title. Roller bearing p bushes required. Would also like uprated springs. Ideally 450lb to fit kw variant 1 coilover. Will consider different rates but no lower than 400lb |
KW's will struggle if you go that stiff, they're valved for 285lb ish.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
Phil white
Hmm, balls... I need to match up to my rear beam with solid mounts, 23.5 tb & 30 mm arb! This is pure track car no roa d use mind, should I chop in for some gaz golds? |
No, get decent dampers.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
Phil white
Not an option, budget track car mate. I'll roll 400lb on the kw and you can laugh when I pop a shocker. Cheers then. |
rich_w
Seasoned Pro Location: Havant, Hampshire Registered: 29 Jul 2004 Posts: 5,412 Status: Offline |
I can supply you a set of Roller Bearing Wishbone Bushes - please PM me if required.Regards, Rich ________________________________________ Contact Details:rich@lynxpowerengineering.co.uk 07732 822546 |
