TT
| Author | Subject: slam panel |
Tarmac terror
Regular Location: Southampton Registered: 20 Mar 2014 Posts: 458 Status: Offline |
OK, sorry to keep asking the same old questions but are all Ph3 slam panels the same across all models?? e.g 1.4/1.8/2.0 etc...TT |
Niall
Seasoned Pro Location: Epsom Registered: 06 Jun 2012 Posts: 1,941 Status: Offline |
Yep |
Tarmac terror
thanxTT |
Tarmac terror
thanxSo what should a ph3 slam panel look like?? This...... or this.... I notice the light apertures are different? Obvioulsy I could look at my own but wondered if anyone had any quick answers TT |
scotzman
Seasoned Pro Location: Dundee Registered: 24 Jun 2011 Posts: 1,408 Status: Offline |
Are you sure they aren't the same? Just the picture taken from different angles.________________________________________ '90 1.6 205 GTi, '98 306 GTi-6 |
just a different angle pic.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
Tarmac terror
Hmmm...now that I see it I think you're right!!! ![]() What a donkey!!! TT |
pebbles167
Seasoned Pro Location: Melksham. Wiltshire. Registered: 08 Dec 2009 Posts: 2,516 Status: Offline |
Tarmac terror
Mind rested .......panel bought!!!Thanks for the speedy help folks TT |
Check for sheared off bolts that would hold the lights in place and that it has the 2 mounting studs that attach it to the car - 8mm I believe (awkward to get to once on car) I find it easier to attach the bumper to the slam panel off the car first then slide the whole lot onto the car. Hockey stick clips go on the wings before the lights go in. Don't forget to re attach the bonnet release cable - you don't need the alarm plug and loom if the replacement has one. I also put grease on light bolts etc to stop them rusting in |
mik
Seasoned Pro Location: Kent Registered: 17 Feb 2011 Posts: 2,100 Status: Offline |
I cavity waxed (B-H S50) mine and put a coat of clear wax (B-H UC) over the whole thing as well. If you need to buy new clips for the top of the radiator, I found they had bigger holes so the correct screws to hold them on to the slam panel didn't work, so I asked the dealer for nuts and bolts instead. And a bit of wax over the bolts once fitted as already said. ________________________________________ Cherry Rallye SOLD |
