Team Diesel
| Author | Subject: Wishbone Question |
cornish_pug
Regular Location: Marazion Registered: 18 Dec 2009 Posts: 368 Status: Offline |
Can a wishbone be turned upside down to be fitted on the opposite side?________________________________________ Team Diesel |
Niall
Seasoned Pro Location: Epsom Registered: 06 Jun 2012 Posts: 1,941 Status: Offline |
No. The ball joint would be at the wrong angle and you would have to take the P bush off and reverse that. |
Capt Pedantic Location: Bigend, Wales. Registered: 27 Mar 2007 Posts: 25,868 Status: Offline |
yes, if you flip the p-bush and balljoint.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
cornish_pug
I've got new p'bushes alloy ones, Naill as far as I can see the location for the ball joint is square to the centre line of the main body of the arm. So like welshpug said just turn over.________________________________________ Team Diesel |
Niall
cornish_pug wrote: I've got new p'bushes alloy ones, Naill as far as I can see the location for the ball joint is square to the centre line of the main body of the arm. So like welshpug said just turn over. Sorry your right ignore me. I was thinking the gap which holds the ball joint was belt upwards but its not, the bend is in the ball joint its self. |
I guess they are all the same from factory till they put p bushes and ball joints on ? |
cornish_pug
bigbadbowen wrote: I guess they are all the same from factory till they put p bushes and ball joints on ? Makes sense ________________________________________ Team Diesel |
fast_eddie
Regular Location: bradford Registered: 21 Jan 2012 Posts: 285 Status: Offline |
How easy is it to get the old bushes out of the old arms?Im thinking of refurbing my original Peugeot arms ive just taken off with uprated bushes etc and keepin the s**te vetech ones as spares for when I have to renew the bushes again ? |
cornish_pug
Grinder but be careful________________________________________ Team Diesel |
fast_eddie
So is that grinder for P bush, or does that knock off?What about the other bush? |
cornish_pug
Grinder on the p Bush never had to change the other bush________________________________________ Team Diesel |
Burn the top hats out the arms makes life easier getting them out |
