displaying posts 1 to 25 of 38
Author Subject: 200bhp club?
Kevwlsn3
Hay guys ive been wanting to have a car that's in this club for ages.. my Mazda were just shy of it with as much as i could do to the engine without going nuts...
been reading a lot on here and was wondering if you think it would be possible to reach this magic number without charging it?
What kinda mods would be needed to reach this without charging?
Any thoughts would be greatly appreciated Smile
kev
Posted 6th Apr 2014 at 10:55
raunchz
Yes it can be reached without charging - piston cut outs, cams and throttle bodies + mapping will get you there
Posted 6th Apr 2014 at 11:05
walker_texasranger
Kev,
This topic has been covered many times on here, use the search key for cams, throttle bodies etc. and you will find what you are after.
Lairy cams, pocketed pistons, throttle bodies and a remap should see you past 200 if you pick the right bits but depending on how handy you are with a spanner will depend how much it costs you. Most big power N/A builds are 2k plus, which means with the price of secondhand charger kits now mainly sub 2 grand, N/A is a more expensive route to glory Thumbs up
Hilux InvincibleX daily
306 No.13 Doh
Posted 6th Apr 2014 at 11:09
Dont need lairy cams, just an inlet cam upgrade and bodies.
Posted 6th Apr 2014 at 11:14
I disagree No it's been tried and tested on just inlet with bodies to get over 200bhp. I've never seen any gti6 engine produce that power fig with just a cam and bods LOL
Posted 6th Apr 2014 at 11:32
RetroPug
http://www.306gti6.com/forum/showthread.php?id=151628&page=6
Posted 6th Apr 2014 at 11:48
That's not just an inlet cam and bodies though !
Posted 6th Apr 2014 at 11:54
eddy_gti6
Fit a v6 and get it mapped then your laughing
Posted 6th Apr 2014 at 12:11
Kevwlsn3
I did not realize the charger kits were so cheap , i am pretty handy with a spanner i am a mechanical engineer to trade Razz
however the i was asking about the N/A route as i assumed this would be cheaper than a charger kit..
By what i have been reading some of the charger kits are pretty much just bolt on ? if this is easier and cheaper i might look in to this aswell.
not looking for a HUGE power increase , maybe past the 200 mark would be fine and i am told these engines would run low boost all day long
thanks for the info tho guys
Posted 6th Apr 2014 at 13:21
calibra306
Loving the V6 crap loads of torque. Ive raced a hispec mazda rx8 and I beat it coming down a slip road and blasting along motorway!
That before I started lightening the car and I had a spare set of shafts in the car also lol
V6 Power!
Faster I can go the better!
Posted 6th Apr 2014 at 13:29
eddy_gti6
Yes charger kits bolt straight on and seem to be pretty reliable too. Quite a few people running chargers now and plenty of info on them on here too. N/A power isnt cheap. Your looking at around £1300 for 2nd hand jenveys with ECU when they come up.for sale whats not very often then you want some cams whats around another £450 then fitting ect, may as well do belt and gasket while fitting came then your going to need mapping. Probably better off buying 2nd hand charger kit and bolt it on and away you go.
Posted 6th Apr 2014 at 13:50
You forgot the piston mods you need to get the best from hotter cams.
Posted 6th Apr 2014 at 13:54
eddy_gti6
All depends on how much far you go if hes only wanting 200bhp. I am running catcam 3107s and mapped ecu on standard engine at 195bhp
Posted 6th Apr 2014 at 14:16
^^^ Exactly, he wants 200, pocketed pistons and higher lift/longer duration cams will give him that.
Posted 6th Apr 2014 at 14:26
eddy_gti6
Or stick a set of jenveys on my engine with a new map Wink
Posted 6th Apr 2014 at 14:41
Kevwlsn3
seems like a lot of changes to reach that number. i dont know nearly enough about the engines to start changing cams and pistons , however i have done it on many different cars ide rather keep this one and not blow it up.
seems like a low boost kit might be the way to go , yea it might give more than 200 but if its as easy as it sounds then i think thats the route i might go down.
Listen to me talk about modding a car i dont even have yet ... still stuck at sea Smile two weeks till i am home.
i might drive the car and love it exactly the way it is , however i got a few friends who are running abotu 200 bhp on cars that weight almost the same. dont wanna fall behind Smile
Posted 6th Apr 2014 at 15:09
allanallen
I've said this before recently(ish) but...... Going back 6 years or so people were allegedly fitting mild cams and having them re-mapped to almost 200bhp, what's changed??
If you've not bought a car and you're dead set on a 306 I'd be looking for a car that's already modded, you'll save yourself loads of time/money.
Or buy a clio, be faster than a 200bhp 306 out of the box.... Razz
Facebook
Posted 6th Apr 2014 at 15:56
Kevwlsn3
Because i am an engineer, there would be no fun just to buy it fast ide like to put some of my own money and sweat in to it.
I have bought a car Razz Lektorious' vile blue one Razz
as much as i like clios ive had my eye on the 306 for a while ..... the speed is just a addition Razz want the 306 for the way it looks heh.
only reason i was asking about the 200bhp is coz i dont want to be left in the burning rubber smoke of my friends Razz
Posted 6th Apr 2014 at 16:52
N/A power is hard to unlock, it's not easy and it's not cheap. It's not like bolting on a charger and you're away. Air needs to get in easier, (ported inlet or bodies) that air needs to be let into the cylinders (higher lift cams) those valves need the space to open longer than they do as standard (standard valve lift is super close to piston contact already) so pocketed pistons are needed, problem with long overlap cams is you'll need more compression to make up for the fact you have to squeeze up the inlet charge in a shorter space of time (so high comp pistons with a big intruder dome are required to increase compression). The ecu needs to be told to make use of the extra airflow by increasing the fuelling (new ecu and mapping needed) if you've done all that (and you can't really do any of that on its own and expect much of a gain) you can expect some very healthy power and an exciting drive. However as that little lot can easily set you back by up to 3-4k it seems too much for too little.
Posted 6th Apr 2014 at 17:30
3rd time lucky
Hmm, i will have to disagree there. Wink
BLACK RALLYE - Sold
CHERRY RALLYE - new toy
Posted 6th Apr 2014 at 17:35
blandy
Seems to be coming back seen a few people hitting, 200bhp+ on just bodies..
Seems all you need in reality is a generous dyno lol
Posted 6th Apr 2014 at 20:29
No, a proper inlet manifold and mapping.
Posted 6th Apr 2014 at 20:32
Rich_W made 204bhp on just a set of PT81 cams, with standard inlet before he went down the charger development route. Yes
Posted 6th Apr 2014 at 22:37
allanallen
Hey we all have opinions, I for instance don't agree with painting inlet manifolds red
Facebook
Posted 6th Apr 2014 at 23:12
dcc
If I'd agreed with you, we'd both be wrong.
205 GTI
Xsara HDI
Posted 6th Apr 2014 at 23:32
