Author Subject: Electric Mirror adjustment issue
doon1988
Had a quick search and cannot see any other posts on this...
The other day when trying to adjust my drivers side mirror - both moved at the same time. So I tried adjusting the passenger side and again both moved.
Is there a common issue here? If I set the control to the central position and try adjusting then that works correctly and no mirrors move...
Posted 27th Mar 2014 at 09:04
either a short in the mechanism inside the switch or wiring looms starting to play up i'd say
Posted 27th Mar 2014 at 09:12
doon1988
So annoying because they are now out of alignment. Even though they both move together it seems one must move faster/ slower than the other as now it is like one is perfect and the other is either just looking at the floor or the sky ha.
Posted 27th Mar 2014 at 09:40
Niall
I would say switch as there is 3 wires to each mirror from the switch so the chances of them pairs shorting together is slim!
Posted 27th Mar 2014 at 17:43
