Author Subject: 88mm crank, what pistons.
peugeot96
im about to build a gti6 engine with a 88mm crank. Any tips for pistons to suit?
Posted 23rd Mar 2014 at 15:59
rallyeash
You can run stock S16 rods and pistons.
Otherwise you will spend a lot of money getting the deck height correct. I have 88mm crank and 87mmm pistons and the rod/piston combo cost me £1200
309 3dr K20 Type R
Posted 23rd Mar 2014 at 16:01
eddy_gti6
Is it worth the hassle running an 88mm crank with s16 rods and pistons tho?
Posted 23rd Mar 2014 at 16:44
peugeot96
l will take the cost. And l want to bore it for more ccm. What kind of pistons/ rods did you use?
Posted 23rd Mar 2014 at 17:32
peugeot96
l wouldnt bother fitting just the 88mm crank and s16 rods and pistons.
Posted 23rd Mar 2014 at 17:35
rallyeash
Well it depends in what situation. If you had a road going car I wouldn't take it off the road, pull the engine out, strip it right down to just put in a 88mm crank.
However if you are wanting a nice torquey budget build then building up a spare lump in the garage or in corporating it within a rebuild, a 88mm crank, S16 rods and pistons machined with bigger valve clearances and some mild cams, retaining the standard inlet is a pretty efficient way to get 200 hp, a 2044cc lump and including rebuild items under £1,000
309 3dr K20 Type R
Posted 23rd Mar 2014 at 18:36
rallyeash
If you really want the CC, buy the 92mm crank and go for 2.2/2.3
309 3dr K20 Type R
Posted 23rd Mar 2014 at 18:37
peugeot96
HahahahaLOL l got a 88mm crank, and that with 87/88mm pistons would be enough for me. So l ll need some pistons with the wristpin 1mm higher to match the 88mm crank. The engine will be fitted with Satchell throttle bodies and some decent cams, and a Dta40.
Posted 23rd Mar 2014 at 18:49
