Author Subject: oil pressure
Niall
Found a few threads but none that really have my answer.
What sort of oil pressure should i be expecting? Im getting about 90psi on idle (cold) dropping to about 40 when the engines warm (although oil wasn't. Ive literally just run it up on the drive).
Also picks up with rpm. Ive heard a general rule is that you should get 10psi for every 1000 rpm but not sure how true this is?
Cheers.
Posted 31st Mar 2014 at 18:59
Sounds about right I think ?
Posted 14th Mar 2014 at 20:03
Thats fine as long as it still does 6bar at 4k.
Posted 14th Mar 2014 at 20:42
ryangti6
I've had a few phase 1's with the oil pressure gauge and that's roughly what they've always had.
They display pressure in bars and cold they are usually about 6 dropping to somewhere between 2 and 4 when warm. Under load they do rise back up but not as much as 10 psi per 1000 rpm.
Ryan
Posted 14th Mar 2014 at 20:45
Mine runs 32psi on hot tick over. (Oil at 80c)
Posted 14th Mar 2014 at 21:28
Niall
Cheers guys. Been out for a drive and got it nice and hot. 30 psi on idle and does pick up nicely with the revs. As long as its not dropping off all together which I suspect could of happened before.
Posted 14th Mar 2014 at 21:56
Niall
So i moved the oil pressure sender the other day as it was butted right up against the charger bracket. Ive now got it in the unused hole in the block where the oil pressure switch was on the ph1. Now on cold idle, I'm getting about 100psi. Is this right? Seems odd its higher on the other side of the engine lol
