Author Subject: Whistling injector??
hsustyle
Hi guys.
Bit of a weird one!
I am getting a whistling noise from (what I'm 99% sure is) an injector.
These are Vauxhall C20XE cream coloured Bosh injectors on a fuel rail on a Cammed 106 Gti, Jenvey ITB.
This noise appears about a minute after running the car in idle and gets progressively louder. Similar noise to a small bird rhythmically whistling or a squeaky alt belt. It's a definitely coming from an Injector.
The noise only happens on idle and disappears as engine revs then comes back when it idles.
Car doesn't bog down or idle irregularly, it been mapped for the bodies a while back too so no s**tty standard map.
What causes an injector to WHISTLE? worn O rings? I am getting a video tomorrow and will check for air leaks with carb cleaner spray.
Also.. I know someone selling refurbished and ultrasonically cleaned C20XE Injectors for a decent price but are injectors affected by a remap at all or will I be fine buying these?
Beef Beyond Belief
Posted 13th Mar 2014 at 22:04
Possibly an air leak causing it - you need to do the spray trick and see what happens. Yes
Posted 13th Mar 2014 at 22:12
aaron6
Its probably cheaper to get yours stripped down and ultasonic cleaned. Simon had his done for £90.
Posted 14th Mar 2014 at 06:06
hsustyle
Couple of bolts on the Jenvey inlet weren't very tight, done them up and now it's quiet.
Cheers guys
Beef Beyond Belief
Posted 14th Mar 2014 at 18:08
Glad it was an easy fix. Thumbs up
Posted 14th Mar 2014 at 21:29
