Author Subject: What sensor is this?
Niall
The grey one immediately above the oil filter plate? I know on the pH1 its an oil pressure sensor but this is on a PH3 so not sure what it is!
Posted 12th Mar 2014 at 19:57
pete-gti
Oil temp sensor?
Posted 12th Mar 2014 at 20:08
Niall
Thats in the sump mate Smile
Posted 12th Mar 2014 at 20:09
eddy_gti6
Oil pressure sensor
Posted 12th Mar 2014 at 20:18
Niall
Cheers Eddy
So the red circled sensor in this photo (PH1 engine), which was the oil pressure switch which is blanked off on my engine, can i use that as a location for a oil pressure gauge sender?
Posted 12th Mar 2014 at 20:24
eddy_gti6
Thumbs up will you be running a separate oil pressure gauge?
Posted 12th Mar 2014 at 20:29
Niall
Yes want to after my recent mishap LOL:
Haven't got room for a plate below the oil filter so would like to use one of the blanked holes in the block.
Posted 12th Mar 2014 at 20:32
pete-gti
Oil pressure sensor that's the one :-)
Posted 12th Mar 2014 at 20:34
Nope, its a switch.
Sender is the larger variant used by the s16 and phase1 gti6.
Posted 12th Mar 2014 at 20:41
Niall wrote:
Cheers Eddy
Yes, exactly that. Yes
On a PH3, the switch is located above the oil filter and the other hole is plugged.
I have used this hole for installing a pressure gauge sensor. Yes
Posted 13th Mar 2014 at 20:46
Niall
stan_306gti6 wrote:
Niall wrote:
Cheers Eddy
Glad to hear that because i fitted the oil pressure sender yesterday with a T piece from the oil pressure switch port and its not ideal at all. No room back there for it and its kinked one of the hoses from the heat exchanger sightly
Posted 15th Mar 2014 at 17:44
eddy_gti6
Is this how you have set yours or have you swapped the purple and red circled switches around? I have my oil pressure gauge to fit and was wondering what was would be best?
Posted 23rd Apr 2014 at 20:10
astor gray 2014
great to this picture ive loads that need to connected on my rallye
Posted 23rd Apr 2014 at 20:19
whatever is easiest, both are pressurised oil galleries.
Posted 23rd Apr 2014 at 20:20
eddy_gti6
Cool thanks mei Thumbs up both will be accessible as i will have my inlet off, just need to see what way will be best to run the wire into the car
Posted 23rd Apr 2014 at 20:26
Niall
Ive now left the pressure switch in the stock place (left hand gallery) and used the blanked off hole for the pressure gauge sender. I had to use the T piece to have it at a 90 degree to the block though as the starter motor got in the way but the sender i have is huge!
Posted 23rd Apr 2014 at 20:28
eddy_gti6
Any pics of yours fitted Niall?
Posted 23rd Apr 2014 at 20:31
Niall
Rather poor photo but you get the idea. The T piece is obviously missing the blanking cap although at the rate it leaked, i may as well have just left it out for weight saving lol
Posted 23rd Apr 2014 at 20:35
eddy_gti6
Cool, that looks to be about the same size sender as i have, may swap the 2 sensors around and see if i can get them to fit.
Posted 23rd Apr 2014 at 20:39
Niall
Tbh it did just sit there between the block and starter but was rather close for my liking and i had a T piece available so thought it would be a bit easier. Its 60mm across iirc from other people whining on the net lol.
Posted 23rd Apr 2014 at 20:40
eddy_gti6
What size is the hole in the block where the sender screws into?
Posted 24th Apr 2014 at 08:04
Niall
I think it's m16x1.5
Posted 24th Apr 2014 at 09:24
