Author Subject: Blower relay
tony1991
Where can I get the green heater relay from. My blower isn't working and also dose any one no which green relay it is there are 3 greens
Thanks
Posted 8th Mar 2014 at 15:58
eddy_gti6
Have you checked the F5 fuse? Should be a 10amp. Failing that I think its the green relay to the left of the orange one
Posted 8th Mar 2014 at 16:07
aaron6
Scrapyard. Pop along, whip one/all out. Thumbs up
Posted 8th Mar 2014 at 17:54
tony1991
I checked the fuse that's all fine. And I got one from scrap yard but can't be sure if it works
Posted 8th Mar 2014 at 18:02
aaron6
Try swapping it for one of the other green relays in your car that are known to work. They are all the same. May be your motor has packed up. I kept burning relays and eventually changed the motor. Sorted mine out a treat.
Posted 8th Mar 2014 at 18:09
tony1991
I only had one in it that's the problem. Since I have owned the car it's not been on the road so hadn't noticed it. Although I have removed the air con should the light come on if I press it?
Posted 8th Mar 2014 at 18:38
aaron6
Posted 8th Mar 2014 at 20:43
tony1991
I only had one green relay in it that's the problem.my old rallye had 3. Since I have owned the car it's not been on the road so hadn't noticed it. Although I have removed the air con should the light come on if I press it?
Posted 9th Mar 2014 at 09:00
aaron6
Should do.
Posted 9th Mar 2014 at 15:14
tony1991
Well mine dosnt come on are the controls common to go or is it likely to be the relay?
Posted 9th Mar 2014 at 15:40
tony1991
Can I get the relay from pug ?
Posted 11th Mar 2014 at 19:56
cully
Green relay is used on the twin fan set up in the triangle between the fans
Posted 11th Mar 2014 at 20:13
