Author Subject: Lightened Flywheels
Hawkesfire
Hi
just found where the disturbing noise is coming from on my car as when i came back from my first test session it had an intermittent noise like a bottom end rattle!!!!!
I pulled the engine out and took the box off and when i went to remove the flywheel it was loose? after inspection it looks like the bolts had bottomed on the crank and it was only nipping the flywheel so once the power was applied on it it worked lose ?
Anyone else had this problem ?
This is a super high boost engine...
Martry
206 Rallycross GTI6 SC SHB 425 BHP clutch eater !!!
Posted 5th Mar 2014 at 12:29
cully
Thanks for the heads up just about to fit a lightend fly will be checking the bolt lengths
Posted 5th Mar 2014 at 12:53
eddy_gti6
I have a lightened and ballance flywheel on mine with standard bolts and has been fine
Posted 5th Mar 2014 at 13:03
flywheel doesn't use "bolts" and isn't into blind holes, so it can't have bottomed out.
Posted 5th Mar 2014 at 14:17
Hawkesfire
So what holds the flywheel on then ?
They can bottom out as they are blind drilled into the crank.
Marty
Posted 5th Mar 2014 at 14:39
Are you using original flywheel bolts ?
Posted 5th Mar 2014 at 14:43
Hawkesfire
Yes why ?
Posted 5th Mar 2014 at 15:12
rich_w
What crank are you using?
The standard crankshaft has thru-holes for the flywheel bolts, so they can't bottom out.
The lightened flywheel has a thinner bolted flange than OEM, to save weight, so you may need shorter bolts if your crankshaft has bolt holes of a finite depth.
Regards,
Contact Details:
07732 822546
Posted 5th Mar 2014 at 15:29
