Author Subject: Rev counter not working at all.
Nose
Hi guys, a bit different to Retropug's post below in that mine doesn't work at all No Its not worked at all since i've had the car tbh, thought it may have been the clock/s itself. But just fitted a replacement set of white needle type clocks and still no rev counter, any ideas guys please? Also the white needle sets clear cover had a crack in it, whilst my original orange set didn't, so i thought i'd swap them over, but i've only gone and bloody cracked the new oneSad Thumbs down so i need another if anyone has a spare please - just off to the wanted section.
Cheers.
Bianca 306 Rallye.
Mondeo Titanium X.
Posted 2nd Mar 2014 at 17:17
RetroPug
Check the loom that runs along the bottom of the rad, unplug and clean up the plugs that plug into the chassis near the end of this loom on the passenger side near the airbox for a couple of ideas to start off with.
Posted 2nd Mar 2014 at 17:27
Nose
Thanks Luke, i'll give that a go mate.
Bianca 306 Rallye.
Mondeo Titanium X.
Posted 2nd Mar 2014 at 17:29
RetroPug
Does the oil level & temp/pressure depending on phase work?
Posted 3rd Mar 2014 at 13:42
Nose
Yeah everything else is fine bud.
Bianca 306 Rallye.
Mondeo Titanium X.
Posted 3rd Mar 2014 at 18:49
luke306rallye
VSS sensor.
Posted 3rd Mar 2014 at 19:02
luke306rallye wrote:
VSS sensor.
"VSS" refers to "Vehicle Speed Sensor" not engine speed which is measured by the crank sensor.
The VSS runs the speedometer, not the rev counter.
Posted 3rd Mar 2014 at 22:42
GTi6-PJL
Hate to bump this one back up to the top, but did the OP ever find a solution? I've got the same problem on mine at the moment - ECU reset & new fuel pump relay (tried changing this on a hunch, but no difference) haven't cured the problem. I'm going to try RetroPug's idea at the weekend, but I'm curious if this fixed the problem or not.
2000 W Phase 3 Moonstone.
Posted 8th Apr 2014 at 19:42
Cjwatson27
I solved mine by unplugging mine several times it worked fine afterwards
Posted 8th Apr 2014 at 19:58
GTi6-PJL
CJWatson27 - do you mean unplugging the clocks, or the loom plug in the engine bay? Forgive my stupidity!
Posted 8th Apr 2014 at 20:00
3rd time lucky
I would expect it would be the loom plugs in the engine bay.
I had the same problem years ago and took the clocks out. Everything looked like new so not much chance of any wiring failures behind there.
BLACK RALLYE - Sold
CHERRY RALLYE - new toy
Posted 8th Apr 2014 at 20:04
GTi6-PJL
Thanks guys - I'll check the loom connections and update this.
Posted 8th Apr 2014 at 20:06
RetroPug
I'd try both...the plugs at the back of the instrument cluter have been known to come a bit loose.
The loom at the bottom of the radiator needs the plug checking, but can also get a small amount of damage and then have corroded or broken wires in it.
Is anything else not working properly? Do the rest of the instruments work? Including oil temp etc.? Does remote central locking work?
Posted 9th Apr 2014 at 09:26
GTi6-PJL
RetroPug - yep, all other dials work (including oil temperature) and RCL works. I'll check the loom and cluster connectors at the weekend.
You gotta love French electrics!
Posted 9th Apr 2014 at 12:17
RetroPug
Hmm ok. The RCL is also carried by the loom near the rad and if that loom is damaged that often goes as well, hence my asking.
Posted 9th Apr 2014 at 13:19
Nose
Wow can't believe its over 12 months since i started this threadShock Well my rev counter worked today for the first time since i got the carBig grin Basically stripped the car down over the last few days ready for painting, which included front bumper removal thus letting us have access to those electrical plugs. Fair play guys, it was a broken red wire that was causing the the problem, wired fixed = working rev counter.Thumbs up
Bianca 306 Rallye.
Mondeo Titanium X.
Posted 28th Apr 2015 at 22:26
Mossy1985
Nice to see its sorted and the fix has been put up, not many people bother with the fixes for some reason Thumbs up
Posted 29th Apr 2015 at 17:41
RetroPug
I've yet to fix mine, been too busy. Sad
I do have a fully-working loom waiting to be swapped on though. Big grin
Posted 29th Apr 2015 at 18:37
