Author Subject: PH3 Drivers front seats backs and bottoms interchangable?
my driver seat has the bottom going but the back is mint!
I may have found a seat with a hole in the bolster so just wondering if i can split them and re-join them easily enough?
to make 1 mint chair?
Cheers in advance! Thumbs up
Posted 26th Feb 2014 at 14:23
no because the driver side is height adjustable
never tried it myself but i read that due to the lift bit it made it impossible
that said, if that was written on here, it probably means it's possible but the person couldn't be arsed
Posted 26th Feb 2014 at 14:28
Thumbs up
well if I get the seat i'll see if I can pull mine apart 1st!
I'd have just thought with the seat bending forward to move you could dismantle that bit and re-attach
Posted 26th Feb 2014 at 14:39
i know on the 205 seats you can swap the whole lot onto an opposite side subframe but the lift handle is in the way so needs bending a touch but apart from that it's fine - and what i'm in the process of doing
but 306 seats i've never looked into properly
Posted 26th Feb 2014 at 14:42
shah_gti6
I've got the same issue on my drivers seat. And I've been told you can spate the two and do this...
Nile Blue 306 GTI-6 (2000V)
Posted 27th Feb 2014 at 18:57
cully
ph2 seat you can remove the seat cusion from the subframe as it is seperat from the back
turn the seat over and its 3 bolts securing the cusion
Ph3 may be the same
Posted 27th Feb 2014 at 19:41
Thumbs up
Posted 28th Feb 2014 at 20:21
rallyestyle
Interesting question Yes Getting to the stage with these cars where we really have to be canibalistic to keep some pretty looking ones on the road LOL
Just Drive It
Posted 6th Mar 2014 at 08:24
