Author Subject: interchangeability high pressure steering pipe / steering pump X
bas_306gti
two questions:
Question 1:
Will the high pressure steering pipe which runs from the steering pump to the steering rack from a Xsara 2.0 16 V (RFS) Phase 2 fit the 306 GTI?
Question 2:
Are the steering pumps the same ?
Greetings,
Bas
Posted 21st Feb 2014 at 21:23
No
You need the rack and the pipes from the xsara as it has different pipe connections
Posted 21st Feb 2014 at 21:33
bas_306gti
Are the connections on the rack different, or on the pump?
Posted 21st Feb 2014 at 22:23
bas_306gti
Went to the local scrapyard;
the early Xsara's P1 fit the 306 gti, the pipes are the same, the later ones have different connections on the rack the pump connections is the same.
Posted 22nd Feb 2014 at 23:46
does the gti6 steering column fit the xsara rack ok?
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 23rd Feb 2014 at 10:04
bas_306gti
Don't know, I only took the pipes because mine are leaking.
Posted 23rd Feb 2014 at 21:21
