Author Subject: Brake servo removal
rhyds
Any tips on the removal of the brake servo on a gti6
Does the dash need to come out?
Posted 16th Feb 2014 at 22:06
As far as I know if the dash was out you could remove it with the whole panel it's bolted to but personally I'd drop te engine right down and forward, then remove the master cylinder and unbolt it from inside the car. The hardest part will be making room for it to come out.
Posted 17th Feb 2014 at 10:36
rhyds
engine is out of the car anyway so thought i might try & fit a pedal box
so in essance, if i removed the master cylinder & unbolt from inside the car, it should just slide out into the empty engine bay?
Posted 17th Feb 2014 at 13:04
pug_306
4 13mm bolts from inside i think on them :-) Or a few 10mm nuts from inside take it out complete with pedal box :-)
1992 205 GTi6
205 Turbo 340bhp
Posted 17th Feb 2014 at 13:18
With engine out piece of p**s then Smile yes just remove the lot at once with ages 13mm bolts
Posted 18th Feb 2014 at 22:47
