Author Subject: Header Tank Setup
eddy_gti6
Looking to fit my R5 alloy rad in the next week or so. Most header tanks I have found on ebay ect... only seem to have 2 outlets, a larger 18mm outlet at the bottom and a smaller 10mm return at the top with an overflow in the filler neck. Is that all that is needed on the header as I have a 106 diesel header what has 1x 18mm outlet and 2x 10mm outlets.
Am I right in thinking the 18mm outlets should go to the bottom rad pipe into the back of the engine and the smaller 10mm inlet goes to the top of the rad?
Posted 14th Feb 2014 at 06:27
eddy_gti6
Anyone help me out?
Posted 18th Feb 2014 at 19:06
rallyestyle
Not sure but this thread might help shine a little light on it;
http://www.306gti6.com/forum/showthread.php?id=159273
Will be interested to see how you get on Yes
Just Drive It
Posted 18th Feb 2014 at 19:14
superchargedblack1997gti6
think Rallyeash
best person to answer this query mate
Snap
Posted 18th Feb 2014 at 19:16
rallyestyle
superchargedblack1997gti6 wrote:
Snap
LOL
Just Drive It
Posted 18th Feb 2014 at 19:31
rallyeash
Got any pics of your setup?
My header only has 2 outlets. The third is the self bleed normally and will return to the top of the rad. It isn't actually required providing you bleed the system proper. This is how my setup is.
Its on a 6 engine yeah?!
309 3dr K20 Type R
Posted 18th Feb 2014 at 19:44
eddy_gti6
Ah so the 3rd one isnt needed? I just wasnt sure weather you had to run a sel bleed with a header tank or weather you could just bleed it as normal.
Ash I have your old R5 alloy rad Thumbs up
Posted 18th Feb 2014 at 19:52
rallyeash
On that rad and a 205 header I had the third one capped off anyhow.
309 3dr K20 Type R
Posted 18th Feb 2014 at 21:37
eddy_gti6
Yeah that rad. Where did your 2 pipes from the header go? Is it the larger one to the bottom water pipe from the rad to the back of the block then the 2nd smaller pipe to the thermostat housing?
Posted 19th Feb 2014 at 05:03
eddy_gti6
Went and bought the billet push adapter for standard plastic take off. Spoke to spoox and got it a little cheaper than lifted so cant complain about that to be honest. Didnt want to be spending £70+ on a conversion...
Posted 19th Feb 2014 at 17:52
