Just going to fit new steering wheel. Got a resistor is it a case of just pushing the wires into the plug on the clock spring behind steering wheel??________________________________________
cherry rallye daily (the money pit)
| Author | Subject: airbag resistor |
chiefton
Seasoned Pro Location: cranleigh Registered: 09 Dec 2012 Posts: 1,195 Status: Offline |
Just going to fit new steering wheel. Got a resistor is it a case of just pushing the wires into the plug on the clock spring behind steering wheel??________________________________________ cherry rallye daily (the money pit) |
cully
Seasoned Pro Location: Cullompton Registered: 12 Jun 2013 Posts: 1,093 Status: Offline |
yup ingition offunplug clock spring remove push resistor into the loom plug or cut plug off and use crimps book says to disarm switch ign off wait 5 mins disconnect battery earth lead making sure accidental reconnection is not possible disconnect SRS module to arm switch ign off reconnect SRS control module reconnect battery earth ensure drivers door is open keep clear of deployment area switch ign on check SRS warning light |
chiefton
Sorted ivfitted it but cant test untill I put my engine back in and c get it all back together. I just pushed them right in and leccy taped it. Cheers mate________________________________________ cherry rallye daily (the money pit) |
