Author Subject: Engine issues
Maxipug
Hi guys, right, just had a longlife 2.25 " system fitted to my 205 gti6 yesterday, and since then it keeps hunting and bogging down when accelerating...
Not to pleased to have shelled out £350 on seeming to make the car worse.
Any help would be appreciated
Max
Mlilley.
205 Gti-6 engine
Bilstein shocks front/rear with Eibach springs
Powerflex poly bushed
Much more to come hopefully...
Posted 12th Feb 2014 at 08:39
RetroPug
I doubt it is the exhaust, however maybe you could try disconnecting the battery for a few minutes and then reconnecting. It'll likely run rough for a few seconds but it'll hopefully settle.
Failing that, it could be a coincidence and a sensor has failed at exactly the same time.
Posted 12th Feb 2014 at 09:59
rallyestyle
Maybe the lambda was damaged during fitting?
Just Drive It
Posted 12th Feb 2014 at 10:41
Maxipug
Cheers guys, will check these out Smile
Mlilley.
205 Gti-6 engine
Posted 12th Feb 2014 at 16:10
darkgti6
Get a diag done. Could be the map sensor, mine ran poorly when it failed.
Team Peugeot Sport 308 Gti�
Posted 12th Feb 2014 at 18:50
pete-gti
Only sensor that has been touched is the lamba so good chance its that :-)
Posted 12th Feb 2014 at 18:53
Agree on the lambda diagnosis - try unplugging it and see if the issue goes away.
If does, new lambda time. Yes
Posted 12th Feb 2014 at 19:12
