Author Subject: Metal Thermostat Take off
eddy_gti6
Anyone got a metal take off for the end of the thermostat so I can get rid of the plastic bit? Ideally want something I can just push my new rad pipe over and jubalee on instead of the push inside with retaimer clip on the standard rad pipe
Posted 10th Feb 2014 at 11:43
The only ones like that I know Of are for 205's for a different rad hose. Think it woul have to be somewhat longer to use on a 6 hose and go in past the metal clip part.
Posted 10th Feb 2014 at 12:01
eddy_gti6
A 205 one would be fine as I am going to make up my own top rad pipe to do away with the oil cooler take off and I will be running a r5 turbo alloy radiator too. I just cant seem to find the ones used on 205s?
Posted 10th Feb 2014 at 12:05
I've found them on eBay before and I think spoox or pug1off do them
Posted 10th Feb 2014 at 13:32
just ask on 205 gti drivers, you'll get one for about £5
dangti6 might have one, for £10
Posted 10th Feb 2014 at 13:43
eddy_gti6
Thanks Rikky al get a post up Thumbs up
Posted 10th Feb 2014 at 14:44
eddy_gti6
This is what I am after, both alloy bit and 205 take off
Posted 12th Feb 2014 at 12:27
allanallen
That's a Bbm ally adaptor http://www.bakerbm.com/205.php?data=thermostatgti6
and a take off is from a 205, put a wanted ad up on drivers, I think they're NFP now
Facebook
Posted 12th Feb 2014 at 13:44
eddy_gti6
I have one up but had no reply and the adapter is £38+vat form bbm. I can buy an adapter for the standard plastic pipe for that LOL
Posted 12th Feb 2014 at 13:47
allanallen
The adaptors use the awful plastic takeoff and clip though Sad
Facebook
Posted 12th Feb 2014 at 14:11
scotzman
this?
clicky
Posted 12th Feb 2014 at 14:13
eddy_gti6
I know thats the bit I want rid of
Posted 12th Feb 2014 at 14:17
that's the setup i use in that photo. think i got the adapter and takeoff for £20 off dcc over on drivers forum
Posted 12th Feb 2014 at 14:20
eddy_gti6
Av posted up just waiting on a reply. Much better set up than the plastic one!
Posted 12th Feb 2014 at 14:44
Yo Eddy, I have one if you still need it, just found it whilst having a rummage.
Posted 5th Mar 2014 at 17:46
eddy_gti6
Am sorted now, bought an adapter for the standard plastic take off. Not the best option. How much you after posted? Might have it anyway
Posted 5th Mar 2014 at 18:23
£15 posted, can bung it in the post in the morning Smile
Posted 5th Mar 2014 at 18:25
eddy_gti6
Posted 5th Mar 2014 at 18:31
This may be a daft question but I don't have the 205 part to look at, can it be mounted to the bbm adapter so that the outlet is facing backwards?
Don't suppose you still have one for sale if that idea is possible do you mei? Smile
Posted 30th Apr 2015 at 22:42
eddy_gti6
You should be able to run them backwards as they only have 2 fixing points what are both located the same distance apart but it will be pointing upwards. Why do you want it pointing backwards?
Posted 1st May 2015 at 00:01
I'm wanting to use a laminova cooler, so my idea was to have it facing backwards, then have a 180 degree hose that goes from that into the laminova, then i can have a relatively straight hose running from the other end of the laminova into the top of the radiator.
Posted 1st May 2015 at 06:48
why not use the original heat exchanger hoses?
Posted 1st May 2015 at 08:27
eddy_gti6
The old BTCC 306 ran it off the bottom rad hose if i remember right
Posted 1st May 2015 at 12:29
I think i'll be getting a different radiator for the setup so the new one probably won't have any fittings to suit the heat exchanger hose.
Posted 1st May 2015 at 17:06
