Author Subject: Clutch cable play
Donksween
Hi just replaced the clutch cable on my phase 3 and I have a bit of play about an inch before the cutch starts to disengage wich is making the biting point very low with it just managing to clear for gears is there anyway to help the auto adjuster take up the play at the top of the pedal ?
440hp evo 8mr replaced wih Moonstone gti6
Posted 7th Feb 2014 at 21:59
Is it the correct cable?
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 7th Feb 2014 at 22:11
Donksween
Exact same as the one that came off mate got it from Dingbro and there usually always spot on
Posted 7th Feb 2014 at 22:23
Donksween
Posted 7th Feb 2014 at 22:24
Could space it but that would be a bodge IMO as somethings not right
Posted 7th Feb 2014 at 23:14
Donksween
Could the gromit not be seated correctly ? To be honest the biting point is the same as with the f#cked cable tho I would have thought the adjuster would have taken up the play at the top of the pedal
Posted 7th Feb 2014 at 23:25
I'm not sure how the adjuster works, nobody on here has every mentioned resetting it for example if u fit new clutch, maybe it's automatic
Posted 7th Feb 2014 at 23:29
The adjuster is automatic. Yes
I suspect the cable is not fitted correctly, more than likely the grommet is not seated right.
Have a look at the routing of the cable too and make sure it's fitted correctly. Once you're sure of that, then stamp hard a few times on the pedal, the adjuster may need to adjust and this is a way of helping it into position.
Posted 8th Feb 2014 at 02:47
